Old 06-21-2004, 08:57 AM
JadeDragon323 JadeDragon323 is offline
Question My 1998 S-10 Blazer has no Power?? HELP
Just brought a used 1998 S-10 Blazerw/108k and it has no power. On the highway the blazer would not go beyond 60mph. Any suggestion as to what I should do HELP???
The steering wheel has a lot of play?? any suggestion. The front- end has a lot of play ex. if I change lanes the blazer doen't feel stable it wobbles.
The abs engages with I am driving 5mph?? any ideas
Question: What does the idle arm control??
Old 06-23-2004, 11:17 PM
chewygoo1 chewygoo1 is offline
For basics inspect your air filter. Also, get an opinon on the condition of your catalytic converter.
Old 06-24-2004, 09:45 PM
wehswarriorS-10 wehswarriorS-10 is offline
Send a message via ICQ to wehswarriorS-10
Re: My 1998 S-10 Blazer has no Power?? HELP
check and see if ur converter is stopped up....if it wont rev high or get up to any speed, then its probably a stopped up converter
Old 07-04-2004, 01:27 PM
kentuc794 kentuc794 is offline
Send a message via AIM to kentuc794 Send a message via MSN to kentuc794 Send a message via Yahoo to kentuc794
steering play
The play in your steering is probably the pitman arm is wearing out. It is about a $100 bucks for the part. It is a little tough to change though unless you have the right tools. I took mine to a garage and they put mine on for $50.
Old 07-04-2004, 03:08 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: steering play
2wd pitman arms DO NOT wear out, they are a solid hunk of iron..4wd pittman arms do wear out, but they are only 30 bux at most autoparts stores... If it's a 2wd the likely culprit is either the ball joints or the tierod
ends and or the idler arm (also 30 bux)
Old 07-05-2004, 06:11 PM
well the pitman arm I have has a bushing on each end of it that is pressed in. I got mine from Napa auto parts and it cost 128.79. If you know where I can get one as cheap as 30 bucks please let me know, a guy I work with also needs one.
thanx
Old 07-05-2004, 07:22 PM
rlith's Avatar
You have the 2wd pitman arm, it doesn't go bad... Yes, it's pressed on to the steering box... What needs to be changed is the link from the pittman arm to the center link (if that is the problem) and it's about 20 bux...
The 4x4 pittman arm is only 30 bux and has the balljoint built into it...
here is a pic of a 2wd set up....
