Old 06-21-2004, 07:59 AM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Angry 1987 electrical problem.
I have a 1987 S10, ( 2.8L 4 spd 2wd ) that keeps blowing the ECM 1 & ECM 2 fuses when I turn the ignition to start the truck. I have checked ( and repaired !! ) the wiring to the gas tank fuel pump, but it is still blowing the fuses. I have all the grounds tight, help !!!
I have torn apart the back wiring harness and have not found any problems. The front is next. I had the fuel pump replaced last year.
Does the relays in the engine compartment need to be grounded ? They are not attached to the fender. OR have I fried my computer ?
Thanks for any help you guys can give me.
Old 11-07-2005, 09:51 PM
Ryan_brink Ryan_brink is offline
Re: 1987 electrical problem.
Try following the wire from the ECM to the fuse block and look for any bare spots and if in doubt just run a new wire all in general, I am doing mine tommorrow I will let you know how it goes.
Old 11-18-2005, 11:00 AM
Drova Drova is offline
mine done the same thing and it turned out to be a bunch of wires running down the firewall behind the motor were grounding on the cab
Old 11-18-2005, 11:01 AM
Post
i believe this is an old thread :S
