Old 06-21-2004, 03:37 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
Angry can you put a tach in a 4 door dx
how hard is it to take the dash apart and find the wire i need for a tach? what wire am i looking for in there to?
Old 06-21-2004, 06:46 AM
audioquattro audioquattro is offline
Re: can you put a tach in a 4 door dx
it is very easy, you just take off your cluster hood, 5 screws i believe, then you take out your cluster 4 more screws, you will need to tap into the wire that if i remember correctly is blue with a white stripe.
Old 06-21-2004, 10:22 AM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
Sorry to jack your thread, but I was wondering if a Si Cluster w/ tach is a direct swap from standard cluster w/o tach. I am assuming it is...
Also, are the Cluster's interchangeable between 88-91? The Shape of the "Cluster Hood" seems to be dirfferent, more round on the newer ones, but can you use say an 88 cluster on a 91 dash if you use the 88 hood as well?
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 06-21-2004, 07:27 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
I think the 88-89's are different from the 90-91's. Not 100% positive but I think so.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 06-21-2004, 11:15 PM
Unhappy
soo whats the wire color of the tach wire?
Old 06-22-2004, 12:35 AM
ok, you CAN swap an Si cluster directly as long as u use the same sub-generation. meaning....if you have an 88-89 use the cluster from an 88-89 if you have a 90-91 use the cluster from a 90-91.
if you dont mind the hassle, you can rewire 88-89 to 90-91 , and vice versa, but you will need the harness lead from the other car, the cluster and the cluster hood, 88-89 clusters are more squareish, and 9-91 clusters are a tad more rounded.
as far as tapping an aftermarket tachometer to your wiring you will need to tap it into the blue wire with a white stripe, as i stated above.
Old 06-22-2004, 02:41 AM
thanks for all the help
Old 06-22-2004, 02:51 AM
BullShifter's Avatar
SEARCH!
http://www.westworld.com/~joe_r/tach/tachinst.html - tach install
Old 06-23-2004, 01:34 AM
no problemo
Old 06-23-2004, 03:54 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
i have both 89 and 90 Si clusters forsale, hit me up with an offer if u want em [email protected]
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 06-23-2004, 10:21 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
This was my very first post on this board...asking about installing a tach. - - nice! - welcome
I cut a hole in my firewall and ran to the blue wire near the dizzy...but it's the same one that's behind the cluster. I also needed the hole in the firewall to run fog light wires, so no biggie.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
