Old 06-20-2004, 10:34 PM
liztic liztic is offline
Question amp cuts out
hey, i'll admit right now to not knowing a thing about my system. i'm using a 300 watt amp to power 2 10" subs. it's wired so there's 300 watts to each sub. when i get the volume up to around 19-20 with certain songs that have a deep bass, it cuts out. the amp that is. both the adjustable knobs are fully turned and the amp is smoking hot!! is one of my adjusters not where i should have it? i put a 20 fuse instead of the 15, wrong or any difference?
Old 06-20-2004, 10:55 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: amp cuts out
You sir should also not be installing **** in your car
www.cloudcity.deviantart.com
Old 06-21-2004, 09:24 AM
thanks for your two cents, but this was professionally installed. open up and read before you criticize!
Old 06-21-2004, 09:32 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: amp cuts out
for Haibane, and you should know who youre talking to before you say anything.
secondly, if certainly doesn't sound like it was "professionally" installed. either that or you messed with it. if it was professionally installed, take it back to them and tell them your problem
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
- Galileo Galilei
Old 06-21-2004, 02:07 PM
Haibane's Avatar
Re: amp cuts out
go back to the 15 fuse btw
Old 06-21-2004, 05:44 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I agree, iffin you paid someone to install it - let them make it work. And never put bigger fuses in unless you know what you are doing, they are set at a certain size for a reason.
Haibane, you on a bent lately about self-intalls ?
Old 06-21-2004, 06:18 PM
Haibane's Avatar
Re: amp cuts out
Yeah... I guess I am in a weird mood. Actually I am a bit too lazy after work nowdays to go back and re explain things even though I should
Old 06-22-2004, 09:13 PM
thanks guys!! as i said rather rudely earlier, it was a professional job, but I was told to adjust the controls as i saw fit based on how i wanted it to sound. i have gone back to the 15 fuse, only switched because i was blowing fuses left and right because how i had it set.....i adjusted it today after consulting someone and it's purring like a dream!!!
thanks again
Old 06-22-2004, 11:35 PM
koeb$ koeb$ is offline
Send a message via AIM to koeb$
Re: amp cuts out
u mie b groundin out but im not sure, does ur protect light come on when it cuts out?
84 TA- 350 bored
dynomaax shorty headers
custom 3" exhaust
electric exhaust cut out
holley 600 cfm carb
340+HP
cam?
97 jetta
white 15" bbs wheels
2 JL 12W3's and 2 JL 500/1 amps (for sale)
Old 06-22-2004, 11:44 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: amp cuts out
your amp is a 300w max wich means 300w bridged to one speaker at prob 8ohms. if you try to hook up two speakers to this amp it will drop it down to 4ohms and that will heat it up quick with input and output all the way up.set at half or get big amp
Old 06-23-2004, 06:32 AM
yeah, i just did that last night, turning to the half way point. a new amp is a certain, just a few other things to do first.......LIKE A NEW HEADGASKET , damn labor charges!!! lol
Old 06-23-2004, 06:44 AM
Re: amp cuts out
^do it yourself, save on labor
- Galileo Galilei
Old 06-30-2004, 05:13 PM
threedd97's Avatar
threedd97 threedd97 is offline
Send a message via ICQ to threedd97 Send a message via AIM to threedd97
Check all of your connections to make sure they haven't come loose. Wipe any corrosion off of the battery terminal with one of those aluminum brush thingies. If the problem persists you may need a bigger amp and/or bigger gauge power lead. Try a 50W fuse and an 8 - 4 gauge wire. I recommend keeping the gain at 1/2 way max.
Seeing how you don't know though, take it to a professional.
UNOFFICAL AUDIO BRAND RATINGS
My life is composed of the worst luck known to man.
Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me.
'98 Grand Prix GT 4Dr
'06 XXX 12"
Possibly a Cadence ZRS-10
Pioneer DEH-5500MP
