Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 06-20-2004, 09:57 PM
bpt323 bpt323 is offline
Send a message via AIM to bpt323 Send a message via Yahoo to bpt323
SI motor wants to die
my 86 SI motor wants to die when i give it jsut a little bit of gas... any clue what could cause this?
Old 06-21-2004, 07:03 AM
87civicfranky 87civicfranky is offline
Re: SI motor wants to die
could be a vacume hose......could be electric problems......what kind of "wants to die" is it???
Old 06-21-2004, 04:00 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Here are a couple of things to check:
Air filter
Timing, coil, spark plugs, plug wires, etc.
Throttle position sensor
Fuel filter
Fuel pressure (bad fuel pump?)
Anyway, thats where I'd start
Old 06-22-2004, 09:34 PM
well i've already fully went through and replaced all of the ignintion components sparkplus,wires, distributer rotor and cap, coil and wire.
i do know however that my Throttle position sensor is bad.
could too high of a fuel pressure cause this?
my return line is restricted in size due to the fact of the motor being swapped into a 1500s hatch back with a smaller return line. its about the same size as the vent line.
air filter is good...
fuel filter is good...
not sure what the timing is set at right now....
not sure what the timing is supposed to be set at quite yet.
does anybody have a throttle position sensor that they will sell me that is still good? or a throttle body?
