turbos
ok well my friend just got a evo 8 so im reading into stuff about the turbo and how turbos work and shit. i know all about superchargers and shit but now to learn about turbos. every once and awhile i see liek stuff about 16g and 12g turbos. and i was talkn to someone about turbos and they said the evo has a 16g turbo. what does the g mean in the 16g? like how do they classify the turbo? and which is better.. cause ive read and seen liek 16g, 12g, 10g, all sorts of numbers with that g. thanks
Oversimplifying things -- there are two components of the turbocharger, the exhaust side and the compressor side.
On the exhaust side there is the housing and wheel. Wheel sizes from smallest to largest -- TD05, TD05H, and TD06. On the compressor side there is the housing and compressor wheel. Wheel sizes from smallest to largest -- 12, 14, 16, 17, 18, 19, and 20. The letter suffix is the trim of the wheel, which is the balance between quick spool versus the ability to compress air over 15 psi. Trims from quick spool/boost below 10 psi to slow spool/boost above 20 psi -- -a, -b, -c, and -g. http://starquest.i-x.net/viewtopic.php?t=504 http://www.turbochargers.com/Turbos/MitsuTurbos.htm Our cars came equipped with Mitsubishi turbos from the factory. So did most Chryslers, a few Saabs and Volvos, and the GMC Cyclone/Typhoon. Other makes of cars came equipped with Garrett turbos. These include most Porsches and Nissans. Examples of Mitsubishi Model Numbers TD05-12A-8CM2 (Starion) exhaust (aka turbine) housing: TD05-8CM2 exhaust (aka turbine) wheel: TD05 compressor wheel: -12A TD05H-14G-8CM2 (Starion) exhaust (aka turbine) housing: TD05H-8CM2 exhaust (aka turbine) wheel: TD05H compressor wheel: -14G TD05H-14B-6CM2 (Eclipse, Talon, Laser) exhaust (aka turbine) housing: TD05H-6CM2 exhaust (aka turbine) wheel: TD05H compressor wheel: -14B It is common practice for turbo rebuilders to port the compressor housings to make room for larger compressor wheels. Examples of Garrett exhaust (aka turbine) housings and wheels: T25, T3, T4, It is common practice for turbo rebuilers to use another manufacturer's housing and install with Garrett flange. Examples of Garrett compressor wheels: Super 60, T61, T88 |
