Old 06-20-2004, 08:16 PM
PyRoTeKniKz's Avatar
PyRoTeKniKz PyRoTeKniKz is offline
Send a message via AIM to PyRoTeKniKz
Lightbulb Am I screwed? *Please Help!*
I was doin the trim on the windows for my R33 and after the paint was done drying I started to peel of the masks. When I took it off I saw some stuff on the window and I was like w/e its just residue and I'll just scrape it off, but when I tried to take it off I noticed it was actually deep scratches...I have no clue on how they got there, but Im thinkin the masking tape might have ripped of some plastic when I was taking it off...Is that possible? What else could it be and how the hell am I supposed to fix this??? I think Im screwed but I just wanted to ask here if there was somthing I could do about it...Please HELP!!!
Heres some pix of the damage:
-Nabil
Projects:
Aoshima Junction Produce Lexus GS - 65% Completed
Fujimi Spoon Honda Civic EK9 - 90% Completed
-Lookin for Work Meister S2 wheels..PM me-
Old 06-20-2004, 08:29 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
it kinda looks like the plastic melted. Id reccommend ordering a replacement from the Company if you can.
Old 06-20-2004, 08:30 PM
-Sk8er6811-'s Avatar
-Sk8er6811- -Sk8er6811- is offline
Send a message via AIM to -Sk8er6811- Send a message via MSN to -Sk8er6811-
Re: Am I screwed? *Please Help!*
dam bro car was looking beautiful. I think your screwed but maybe someone here can help. May i suggest making some windows from clear plastic, like the mod plastic. Once again sry to here about this hope you find a solution soon
-Sk8er6811~Visit My Model Site~
Old 06-20-2004, 08:37 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
What kind of tape were you using? It looks like the adhesive melted the plastic. Call TamiyaUSA, tell them the kit, parts tree it came on and they will send you another one free of charge. Search for the thread where somebody gives TamiyaUSA "props".
-Mike
Old 06-20-2004, 08:47 PM
Alright thanx guys
I was using regular masking tape, maybe i shuda used painters type tape
-Nabil
Projects:
Old 06-20-2004, 09:00 PM
3M makes really good tape! check that out. I think Mike hit it right on the head...adhesive melted the windows.
Old 06-20-2004, 09:06 PM
mike@af's Avatar
Be careful though. Some 3M does leak (regular home paint tape tends to sometimes). 3M Blue Plastic tape (found at auto paint stores) is and excellent tape, a little pricey but it does the job. Tamiya Masking also works very well.
-Mike
Old 06-20-2004, 09:08 PM
Vric's Avatar
Vric Vric is offline
It look like it got some heat.
try transparent Styrene (cost about 1$/sheet) you should be able to make a new one
Old 06-20-2004, 09:34 PM
Thanx for the tips guys, I just wish I knew that b4 heh
Also Mike thanx for lettin me know bout TamiyaUSA, I called um up but there closed so Ill try again tomm.
-Nabil
Projects:
Old 06-20-2004, 11:09 PM
Skateforfood's Avatar
Skateforfood Skateforfood is offline
Hey pyro, if you find that url will you post the link? I had a prob were my paint had bled threw the tape and I also need a new Honda s2000 Windsheild. Thanks...
Old 06-20-2004, 11:43 PM
SchuberT's Avatar
SchuberT SchuberT is offline
http://www.automotiveforums.com/vbul...t=tamiya+props
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 06-21-2004, 08:20 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Have you tried to clean it up? It's obviously hard to tell from pics if the plastic is deeply etched, but it seems like it'd be worth the try. Strip the paint with your favorite method- if it's enamel, I highly recommend CSC or similar, if it's Tamiya acrylic, window cleaner or alcohol tends to work very well also. Then, take a bit of toothpaste (not gel) on a cotton ball, and polish the effected areas. Toothpaste has extremely fine abrasives in it, and is great for this type of problem. Add a bit of water if necissary. If this works, the toothpaste will leave a very fine haze, which can be removed with Tamiya polishing compound or the like.
I would at least give this a try before ordering a new set- or (gasp) attempting to scratchbuild a replacement. Recreating the curves of the windshield almost makes this a non-option. It can be done, by hot stretching clear thermaform plastic (not styrene!) over the kit part. If you're keen to try, I can tell you how, but the supplies you need will likely be more expensive than ordering a replacement set of clear parts. Making decent clear parts tends to require very advanced scratchbuilding skills- unless you like the flat plate glass windshield look.
The best option is, if the kit part proves to be unusable, order a new set of clear parts from Tamiya.
PHOTOBUCKET SUCKS
Old 06-21-2004, 10:36 AM
MPWR, I have tried cleaning it with rubbing alcohol cuz thats what usually takes off the residue for me and I was also considerin using GooGone(very effective stuff) but when I found out it was actually scratches, theres no point. Im pretty sure they are scratches tho because when I run my nail over it, it goes down and in..
-Nabil
Projects:
Old 06-21-2004, 10:59 AM
Vric's Avatar
I can't imagine how you scratched the windsheild like that. Quite strange
Old 06-21-2004, 12:50 PM
Re: Re: Am I screwed? *Please Help!*
I think so too. But I can see the melted plastic in some pictures.
AF MODELING FAQ
"Oh what a feeling.- Toyota
