Old 06-20-2004, 05:25 PM
CR50HC CR50HC is offline
Question My Cylinder Compression test values?
ok folks, I just had a compression test done on my 89 CRX DX. There was some oil on the number 2 spark plug when we romved it for the test. Anyways, the guage readings are as follows:
Cyl 1- 235 Psi
Cyl 2- 245 Psi
Cyl 3- 230 Psi
Cyl 4- 235 Psi
Can you folks tell me if these values are good, bad, average, within factory spec??? I beleive the oil on plug #2 indicates a worn valve seal. the car has 218,000 miles on it.
Troy
Old 06-20-2004, 05:36 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: My Cylinder Compression test values?
Was this a dry test or with oil?
Old 06-20-2004, 07:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
You must have done it wrong, those readings are really high.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-20-2004, 07:18 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
it could be because with that much miles on it, coudl have alot of carbon build up and have high compression
Team Lonely Drivers
Old 06-20-2004, 09:53 PM
There was oil in the car if that's what you're talking about. Will high compression cause any problems? Should I think about doing some major maintenence on the engine?
