Old 06-20-2004, 04:49 PM
Bigceeloc's Avatar
Bigceeloc Bigceeloc is offline
Send a message via AIM to Bigceeloc Send a message via MSN to Bigceeloc Send a message via Yahoo to Bigceeloc
Question Routine maintenance around 100k
Is there any routine maintenance that should be performed around 100k? Such as timing belt or water pump or whatever. Anything?
I'd like to know because I just bought my car w/ 105k on it.
Old 06-20-2004, 05:50 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Routine maintenance around 100k
Routine maintenance should be outlined in the owners manual. Usually on most cars it deals with changing the oil, servicing the transmission and changing platnium spark plugs. If you have a 4 or 6 cyl engine there shouldn't be a timing belt that needs to be serviced because most of them have timing chains. You might want to consider having the coolant checked to make sure it is in good shape along with the hoses and the serpentine belt. If all of these are in good shape you should have no problems. You can order an owners manual from your dealer or check e-bay as you can usually find one pretty cheap.
Old 06-20-2004, 05:55 PM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
i bought mine with 94k in october.. and had the oil changed, coolant changed, transmission fluid & filter changed, just to give it a fresh start.
If things like the water pump work fine,
i wouldn't really put money into unless needed
Old 06-20-2004, 06:52 PM
Bigceeloc's Avatar
Yeah I'll be changin the oil tomorrow. And I should prolly find out how to change the fluid and filter as well. Thanks!
