1 week ago I purchased a 1992 ram 250 mark 3 conversion van w/t a 318. It has 54,000 miles on it and ran great for a week. Two days ago my wife went out and started it and forgot somthing in the house shut it off and it would not restart. About twenty min. later it started I drove it about three miles and it cut off. Twenty min. later it started again drove about 2 miles and it shut down again. Finally got it home and It has not started since. I started checking things and found out it has NO power to the coil I checked all the relays I could find with no luck. i checked the ERG,vacum lines, crank and cam sensors with no luck. It did not ever throw a check engine light it has no stored codes the batery is brand new I tried every thing I could think of. can anyone tell me what would cause it not to have any spark. I would think if the crank or cam sensor went bad it would give you a check engine light. I am not great with electrical systems so if someone has a clue to my problem please help. I still owe money on this thing
Re: van will not start
im not sure about vans but a crank sensor will give a code 12 ...this is normal during code retrival...so you cant tell if the crank sensor is bad or not with out going deeper ...also check all fuse for ign and fuel ...did you check out the auto shut down relay
a '92 318 van?
Bad distributor pickup? Bad coil? Bad SMEC (computer, or ECM whatever-you-wanna-call-it) Bad Ignition fuse link? Bad Van? (just kidding)
If I knew what I did to break it, I would've known not to do what I did.www.classicwinnebago.com |
Sounds like a case where someone knew something was wrong, so they patched the problem quick and dumped it/traded it.
When something breaks 1 week after a purchase, you can usually say pretty surely that the vehicle was beaten and/or neglected maintenance...
My Mopars |
Re: Re: van will not start
Sounds like a crank sensor. I had one that was intermitent like you describe.
I have the same problem.Im trying to find a way if posible to bypass the sensor.what a nightmare.
i have the same problem
i swapped my crank sensor with a working van and the working van worked with my non working crank sensor so that rules out the crank sensor i also swapped the coil and complete distributor i cant figure out why i have no spark if any1 can help me please advise |
You may have a bad PCM. Located above the engine on the firewall inside the engine compartment.
