Old 06-20-2004, 03:25 PM
esqurt esqurt is offline
93 lesabre won't crank
I have a 93 that won't crank or start, the security light stays flashing while you try (all the time key is on). I have bypassed the starter and it will start and run for 1 second. I have checked all fuses and relays. I tryed a new key but didn't help. I have voltage from the key switch when you test with a meter. Any help would be welcome.
Old 06-21-2004, 05:56 PM
Jed Rule Jed Rule is offline
Re: 93 lesabre won't crank
It broke the VATS wires at the ignition switch. You'll need to replace the ignition switch or jump by-pass the VATS system with the correct resistor.
See this forum (or the Park Ave) for more information.
