| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
Ok I feel bad for asking this because I know I've seen it somewhere on here before in a thread; but I've been searching for the past hour around the board and haven't been able to find it again. Yes before you even ask I do feel like a jackass.
Against what the majority of people say, my friend has decided to use an fmu (vortech or greddy) and a boost retarder in place of his AEM EMS. But he doesn't know exaclty how much to retard so he doesn't blow his motor up. He has an H22a and is going to be running 14-16psi of boost with I believe 9.3:1 compression (i could be wrong about the compression though i will try to find out for sure if it's important.) But what I was looking for is the ratio for the retarding; how many degrees of retard per how many psi (or bar) of boost? I thought it was somewhere around 1° per 10psi but I don't think that's exactly on. Any help is greatly appreciated. Please have pity for the ignorant. |
a conservative number is .75 degrees per pound of boost
so i dont konw full timing on a h22a, but on a b series its 30 so if they are the same on an h series he should be running around 18 degrees of timing. then on the dyno and keep adding timing till you start to lose power then pull a few degrees and then your set |
Re: Retard timing to boost ratio?
wow i was way off with the 1:10psi thing then. Thanks for the help i appreciate it.
damn..i think im off then....I switched back to OBD-2 and hooked up the scan tool and I am idleing at about 25 and the car goes down to about 19-20 under boost.
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights, 2000 Integra Type R: Totaled
how much boost you runnin at 19-20 degrees
what are you using for engine management ? obd1 is the best |
I would switch it back to obd1 and use uberdata. It has built in features that allows you to set the amount of timing retard per pound of boost and a bunch of other goodies. It will give you the best management for minimal costs.
yup exactly what he said, uberdata, its really cheap and just as good as hondata.
plus real easy to make base map |
