Old 06-20-2004, 01:59 PM
texastahoe texastahoe is offline
Unhappy 2000 Tahoe window won't go down
I just started my 2000 Tahoe and the driver's side window suddenly won't go down (it's in the up position). I think what might have caused it is I absentmindedly hit the window-down button while trying to start the car, and I think I heard a click and now the driver's side window doesnt go up or down. It doesn't make any sounds either - no clicks or hums, or motor sounds. But all other 3 windows operate fine.
I drove a 74 Nova for 10 years and now just bought this Tahoe, so I'm pretty new to new cars and don't have a clue what is causing this window problem... any ideas?
Thanks.
Old 06-20-2004, 02:19 PM
Rodie40's Avatar
Rodie40 Rodie40 is offline
Re: 2000 Tahoe window won't go down
If you are carefull, you can pull up on the front of the switch plate By the speaker grill (if there is one) and check the wiring plug under it.
Dan O
1966 Chevelle SS Big Block
2007 Dodge Ram HEMI
1992 Miata
1997 Pathfinder (For Sale)
2007 Camry
Old 08-09-2004, 01:08 AM
Willie0508 Willie0508 is offline
Go to the fuse box in the cab on the drivers side also under the hood there is a fuse box on the passnger side i thank i will be in the same place as the drivers also check the relays i had a ford that did that clickin is the relay there ya go
