Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-20-2004, 02:50 PM
AlexFromRomania AlexFromRomania is offline
timing marks
I'm trying to check the ignition timing on my 94 sentra but I can't find the timing marks. I connected the inductive timing light to the first spark plug wire and I aimed at the crank pulley on the engine block but I can't see the timing marks anywhere. Can anyone give me some advice on what I'm doing wrong?
Old 06-21-2004, 01:21 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: timing marks
just look waaay down in there. You'll see a little metal pointy thing sticking out over the belt with the marks.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 06-25-2004, 09:03 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: timing marks
You will also need to disconnect the Throttle Position Sensor first, to get the correct base idle.
