1987 clipper cabrio won't start
Have a 1987 Golf Cab. after changing head gasket, seemed to be running OK. Took it for a spin to check it out and oil light and alarm came on. Changed two oil pressure sensors. Took it for a spin, OK initially, but after a while oil light and alarm came on again. Changed oil pump. Won't start now, no spark. Doesn't seem to be firing on all cylinders. Think I checked obvious connections. Help, don't know what to do next.
Re: 1987 clipper cabrio
poor wiring at oil sensor/switched wires on sensors.no oil pressure no start,(some models)
mechy1barry
Thanks very much for your advise will check. Cheers
You may have to reset your distributor position. Put engine on TDC #1 & check the distributor position (notch on housing should align with the rotor).
boschmann
Thanks for the help, very much appreciated, will check.
