Old 06-20-2004, 07:53 AM
debb718 debb718 is offline
high idlel
i have a 87 jeep cherokkee that at startup idlel real high won,t kick down what could be the cause any advice please
Old 06-23-2004, 04:28 PM
Saudade's Avatar
Saudade Saudade is offline
Re: high idlel
Lot's of stuff. Could be a vacuum leak, could be a bad sensor, could be a linkage problem.
Old 06-23-2004, 06:38 PM
Dale Aeppli Dale Aeppli is offline
Re: high idlel
hi probably your throttle body need cleaning. should also check the throttle position sensor, this is a common cause of erradtic idle. dale
[email protected]
Old 06-25-2004, 01:13 AM
mieth mieth is offline
Re: high idlel
Not sure what engine you have, but on my 89 JC with 4.0L inline 6 cylinder I had this same thing happen due to a defective Idle speed stepper motor. It costed $87. Make sure you follow the directions that come with the sensor for initial adjustments.
Good Luck.
Old 10-03-2004, 06:39 PM
fred bear111 fred bear111 is offline
Re: high idlel
simple fix cost nothing. and is permanent. take out the ips, unscrew the plunger take it out with the plastic spacer and put a thin washer (i used a small star washer) beneath the plastic spacer and put it back togeter. totally stops the rev up. note if washer is too thick the unit wont seat down
