Old 06-20-2004, 12:25 AM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
Question head gasket
doing a head gasket job on my B18A1 and was wondering how to put it in timing. i should just have to get #1 Piston at TDC and cams notiches at top and the white lines to line up right then put belt on. let me knwo if i missing anything.
For You Are Crunchy And Taste Good With Ketchup!
Old 06-20-2004, 12:48 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
that should be it but there might be somethin im forgetting, just wait a little someone will bring somethin up
88 civic dx
Old 06-20-2004, 12:54 AM
krustindumm's Avatar
krustindumm krustindumm is offline
Re: head gasket
very important...
put the piston @ TDC according to the notch on the crank pully. install the adjuster and spring, tightened at the loosest setting. Put the belt on the crank pully, then the adjuster, then water pump, then cam pulleys. release the adjuster. turn the crank counter-clockwise three cam teeth (watch the cam gear to move 3 teeth, then tighten the adjuster. DONE. I just did this a couple hours ago, it is what the FSM recomends and it works great.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 06-20-2004, 12:14 PM
Hybrid1990crx's Avatar
Re: head gasket
or also to set it to TDC you can take a long screw driver and take out the spark plug from cylinder #1, which is the one closest to the timing belt, and put the screw driver down the hole and then turn your crank. Once you see the screwdriver come all the way up and start to come back down thats almost TDC, now back it off just a tad and you've got tdc. Very easy. Then to set your timing, I sudjest using white out or something that won't rub off and make two marks on the cam gear and timing belt. No way to screw it up that way.
Old 06-20-2004, 02:07 PM
91civicDXdude's Avatar
Re: head gasket
why bother with the screwdriver when all you have to do is line up the TDC mark on the crank pulley... your method seems a bit crude and primitive and also innacurate.
Old 06-20-2004, 08:55 PM
Re: head gasket
Whatever man, I think my way is just as good. I dont have to take my wheel off to look for the mark.
Old 06-20-2004, 09:01 PM
Re: Re: head gasket
lol. open the hood, look down at the crank pulley, if the TDC mark isnt lined up, turn the crank pulley bolt (which you can easily get to by turning the wheel to the left).
you still have to turn the crank pulley bolt with your method, only you dont check to see if the mark which was purposely put there to set the engine at TDC. :P
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: head gasket
why would you take the wheel off, you can see the mark from the top of the engine.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-20-2004, 09:05 PM
Re: head gasket
I dunno, I never did it with the mark so I don't even know where it is.
Old 06-20-2004, 09:06 PM
Re: head gasket
if you dont know where the timing marks are, that tells me you've never set your ignition timing.
you might to look into that :P
Old 06-20-2004, 09:14 PM
Re: head gasket
Nope, haven't had to do that before.
