Old 06-19-2004, 08:59 PM
Sava Sava is offline
surges of power upon acceleration
1997 S-10 4.3 5spd. When accelerating the truck surges and slows and surges again. What could this be?
Old 06-19-2004, 09:59 PM
TopDogg TopDogg is offline
Start witht he little things first.
How about the fuel filter?
Old 06-20-2004, 08:30 PM
Re: surges of power upon acceleration
No dice with the fuel filter... plugs, wires,?
Old 06-21-2004, 06:50 PM
MISTER C MISTER C is offline
had same problem ,change wires and plugs still had problem ,change oxygen sensor problem went away,also could be clog fuel injector.
Old 07-23-2004, 01:42 AM
dwinthrup dwinthrup is offline
have 98 2wd 2.2 same prom i replace primary o2 sensor no luck
Old 07-23-2004, 07:59 AM
TuckerR1980's Avatar
TuckerR1980 TuckerR1980 is offline
Send a message via AIM to TuckerR1980 Send a message via MSN to TuckerR1980 Send a message via Yahoo to TuckerR1980
One easy check would be to take one of you gas supply lines and see if your pump is pumping a steady stream or if it's starting to sputter a little. Once you rule out that your getting enough gas to your injectors it narrows things down a little.
Old 07-23-2004, 08:11 AM
jeeptec jeeptec is offline
Just do what i did when i had that problem. i pulled my motor out and am dropping a 350 4 bolt mane in it. no computers or none of that stuff.
Old 07-23-2004, 02:35 PM
smokey041369 smokey041369 is offline
disconnect the catylic coverter see if that helps and check the fluid level in the trans
