Old 06-19-2004, 09:54 PM
Sava Sava is offline
Tranny noise
1997 4.3 vort. manual trans- 130,000miles, All gears working fine but, noise is present when clutch is not engaged or driving. I believe its the throwout bearing. Need new clutch package...factory or would another supplier be better?
Old 06-28-2004, 12:56 AM
CreeperSteve CreeperSteve is offline
Send a message via AIM to CreeperSteve
hey, I had the same problem and it turned out it wasnt the bearing. I had no fluid in the trans. check that first and if that dosent stop it, it may be the throwout bearing.. but do it fast cause my trans is now screwed up permanantly because i was drivn for so long thinkin it was the throwout bearing
Old 06-29-2004, 07:53 PM
spasticone spasticone is offline
Re: Tranny noise
Also... Check your pilot bushing! I have had may of them go out. Lube it well if you do a clutch. If it were a throwout bearing, it would make noise when the clutch was engaged. the input shaft on the tranny goes out VERY quickly if the pilot is left go.
Also, shop around for the best price on a NEW kit. Don't go with a reman disk
