Old 06-19-2004, 08:22 PM
elvis45373 elvis45373 is offline
Exclamation Help, installed new amp, car won't turn over.
Just installed an amp and sub in 97 Jeep Grand Cherokee. Tapped into power by factory amp. Just before attaching wires to amp, blew factory amp fuse in fuse pannel. Replaced fuse, but then the factory head unit acted like the car was shut off not running in aux(display blank, press in on vol knob for time). Checked all the fuses(three times), none bad. Then charged the battery, Stereo works again and the subs are on too. PROBLEM: Went to start the Jeep, it wont turn over. If i lay into the gas it will turn over but will stall as soon as I let off the gas. Un-hooked the Amp, Checked fuse boxes inside and under the hood. all fuses are good, relays? dont know how to check them. New to forum, but in a spot, would appreciate whatever help you can offer.
elvis.
Old 06-19-2004, 09:39 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
question #1 ..... why did you tap into the fuse block ?
Old 06-19-2004, 10:11 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Help, installed new amp, car won't turn over.
yeah... not the best idea
www.cloudcity.deviantart.com
Old 06-21-2004, 10:02 AM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Get car started first then go to fixing your audio problems. Check all the fuses in vechicle. Now I am not a Jeep guy but there are a few things iwould check. First is the fuses..next does it have a shut down for the fuel pump? If so check that. Next check where you made all your connections. Did you accidentally cut a wire?
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 06-21-2004, 05:38 PM
Audio Guy
I agree with sickvette ... an awesome stereo is pretty much worthless if the car doesn't run
