Old 06-19-2004, 07:52 PM
tigger81 tigger81 is offline
starving for gas
I have a 90 lumina 2.5. I have just replaced the fuel pump 2 days ago, and it was running fine. Now the thing keeps dying on me. It will start right up, reverse just fine, but when I put it in drive, the car starts dying. I checked my fuel filter and added some Heet, But nothing works. Any ideas?
Old 07-16-2004, 12:40 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: starving for gas
O2 sensor might be your problem. i'm not a big fan of the 2.5's I had one, nothing but grief. Good luck with it.
Old 07-17-2004, 05:40 AM
98Lumina's Avatar
98Lumina 98Lumina is offline
Banned
Send a message via AIM to 98Lumina
It's a long shot, but try increasing your idle. Reverse runs at a lower gear ratio than 1st, so it is easier for the engine to move the car. I assume you're driving an automatic which means your foot is probably on the brake when shifting into first. The low RPM's and the relatively high gear ratio may be causing the stalls.
Old 07-23-2004, 01:11 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
AIR IN YOUR FUEL LINE. Bleed it using the schrader valve at the end of your fuel rail.
