Old 06-19-2004, 07:34 PM
Hybrid1990crx's Avatar
A6 dizzy on a ZC?
I might be getting a dohc zc sometime soon, but it needs a dizzy, will the one from my a6 work? I'm pretty sure it won't, but I just wanted to check.
Old 06-19-2004, 10:04 PM
91civicDXdude's Avatar
Re: A6 dizzy on a ZC?
i dont know for sure about this, but from what i know about hondas, you can make it work. as long as the distributor itself fits into the cam slot, it doesnt matter if the bolt holes line up, it can be made to bolt on. the ZC distributor has the CAS on the exhaust cam instead of inside the distributor, but you can bypass the internal one in a normal a6 distributor..
why dont YOU be the deciding factor here... If you get the DOHC ZC, try it and see if it works..
Old 06-21-2004, 01:49 AM
joebowlr21 joebowlr21 is offline
Send a message via AIM to joebowlr21
You have to use an 89 integra dizzy.............
