Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-19-2004, 07:18 PM
nbuhr nbuhr is offline
i got a turbo of question
i thinking of putting a turbo on my 93 teg ls. well i dont know too much about the turbo or what to look for when buying one. so here are my wonderful questions to you all. What should i look for in a turbo kit? my car has 130k miles on it what do i have to do to get car ready for a turbo? and what do u recommend to me? any help or links to information is wanted.
thanks.
Old 06-20-2004, 01:46 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: i got a turbo of question
i wouldn't recommend turbocharging a motor with that many miles on it.. it's just not safe, you'll blow it pretty quick if you try and push any psi through it.... maybe you'd be safe with 5 at max if you want your engine to last any amount of time.. maybe go for a swap first?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-20-2004, 08:04 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
just for your information, there is a turbo forum in the honda/acura section with a lot of great info in it and some intellegent people to go with it, you might get some better answers in there.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 06-20-2004, 09:13 PM
98-integra 98-integra is offline
130k miles isnt really alot for a honda
you should do a leak down check and compression test
Old 06-21-2004, 06:40 AM
YellowITR479 YellowITR479 is offline
First thing you need to do on your car is get a compression check. If all 4 cylinders are within normal ranges and holding pressure then there is no reason why you cant add a little boost in your life. Just make sure you do your research if you decide to "frankenstein" your kit. You will need a fuel system matched to what you have and would be an investment to get a lil dyno time to fix your power curves so you do not ping or detonate and risk spinning a rod or something bad like that
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-21-2004, 07:11 PM
charlieteg charlieteg is offline
Send a message via AIM to charlieteg
ok this might be a dumb question...what do you mean by frankenstein?
Old 06-22-2004, 09:06 PM
rak3 rak3 is offline
Ok Frankenstien! Build it yourself
Old 06-23-2004, 07:02 AM
yea....can also call it piecing it together
