92 Camry Distributor Capacitor
My 92 Camry 5S-FE 4 cyl. stopped in its tracks after blowing the lower hose off & getting HOT... It was blowing the 30 amp AM2 fuse under the hood after I had fixed the lower hose problem....
I started taking componets off circuit to narrow it down... I thought it might be the Ign. coil because of the Heat... WRONG, it was the little Distributor Capacitor (mounts inside of distributor with a outside screw)... This capacitor (old timers called them condensors) looked like it got HOT as the plastic was ozzing.... It has a dead short with my Fluke Ohm meter... QUESTION... Does anyone know where I can purchase this Capacitor or know the Value ____ & working voltage ____... Your help would be much appreciated... Bob
Bob South Mississippi 92 & 94 Camrys |
Re: 92 Camry Distributor Capacitor
Did you try Toyota? I would use only the OEM part. The quality of capacitors can vary alot even when they have the same voltage/capacitance
Thanks Brian...
Will call Toyota on Monday morning.... Bob |
Just a follow-up......
Installed the Condenser & fixed the problem... Toyota Part # 191133-16240.... $2.87 cost... Wander how many distributors have been replaced just for this small condenser being shorted...??? Just a note... Need to set Gap of magnetic sensor that you have to remove to get the condenser out... Bob |
Toyota Part# correction 19133-16240
Also sold by Standard Motor Products #RC22 (Capacitor-Radio Suppressor) |
Great - thanks for the correction and alternative source.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
I used an AutoZone part...of course, now that I've admitted it, it'll crap out on me.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
