Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-19-2004, 05:18 PM
Truckguy55 Truckguy55 is offline
Angry 89 jimmy fuel pump problems
Hey everyone I have an 89 gmc jimmy 4x4 automatic. I am having some problems with the fuel pump. I have replaced the original pump with a brand new one because the stocker went out. I get a good power source to the pump and the pump works when i hook it up to a 12v battery charger. So the pump works outside of the tank but once you set it up in the tank it doesnt want to pump fuel. I have talked to 10 different guys and none of them know what the problem is? Please help me on this!! Thanks!
Old 07-02-2004, 12:11 PM
hilljack hilljack is offline
I have a similar problem are you getting voltage to the pump? I'm not sure if the harness is accessible. I just started looking at mine today.
Old 07-03-2004, 03:17 PM
NJTy180's Avatar
NJTy180 NJTy180 is offline
Send a message via ICQ to NJTy180 Send a message via AIM to NJTy180 Send a message via Yahoo to NJTy180
Re: 89 jimmy fuel pump problems
depending on the brand of pump, you might need a higher amp fuse in there. I believe its the ECM-B fuse that controlls the pump and its probably a 10amp fuse, if its blown, upgrade to a 15amp fuse.
However if its not blown, there is possibly a ground problem.
morgan
93 gmc typhoon . 92 gmc typhoon . 93 toyota celica gt . 70 chevy el camino ss
Old 07-04-2004, 08:22 AM
shrkarx2 shrkarx2 is offline
Verify ground, Does the pump ground to the tank & the tank to the frame? If so you wont have a good ground untill install is complete.
