Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-19-2004, 03:04 PM
dap08 dap08 is offline
runaway idle
95 intermittent idle problem ...gradually gets higher on highway up to 2500 rpm....braking becomes impossible. put in neutral..rpms go nuts..up to red line shut off...restart rpms up to 2500,,,revving to redline & 2500...cat conv red hot...smoking.
let cool down for 1/2 hr restarts ok...sometimes.
have replaced fpr,plugs,wires,egr valve,pcv valve, fuel pressure sensor.
any ideas? hard to restart sometimes..long cranking.
Old 06-19-2004, 03:40 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
Re: runaway idle
Hard starts = Fuel Pressure Regulator (common problem)
Also your cat is clogged, get it replaced. High flow is nice, probably cheaper then the OEM replacement. And you will get more exhaust kick
I would also get your Idle postitioning sensors and TPS checked out.
Braking becomes impossible? how?
Sounds like your car needs a bit of TLC right now
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
