Old 06-19-2004, 02:31 PM
markandjess2003 markandjess2003 is offline
2001 2500 HD blows hot air while idoling
I have a friend who is a mechanic, sort of, and he has a/c manifold gauges, i do residentail work, so i figured i would see what the gauges read. When I put them on, the liquid side would rise up to retard causing the compressor to go out on overload then when it would drop, come out of it then go right back up as fast as it came down. My thoughts were maybe the metering device between the ports? But it only does it while idoling, when i get out on the highway and rev it up it seems to work fine. Any ideas?
Old 06-19-2004, 04:24 PM
Redneck_Cadillac's Avatar
Redneck_Cadillac Redneck_Cadillac is offline
Re: 2001 2500 HD blows hot air while idoling
your high side pressures will fluctuate as the clutch kicks in and out.
what are your psi's when the compressor is running with the clutch engaged??? if it's fluctuating often, (every 5-15 seconds or so) it sounds as if the charge is low....
i believe it should be 32-34 low psi and 180-200 high psi. (high side) not positive about that.
the warm air is due to lack of refridgerant and the condensor is hot. at higher rpms.... it's circulating and works much better.......
I haven't, nor ever will claim to know everything about cars..... but a big f*cking hammer can fix most problems.....
Old 06-19-2004, 07:43 PM
mjgjr72 mjgjr72 is offline
if its cold when driving and hot at idle you might want to check the clutch fan if it has one, kinda sounds like not enough air flow across condensor, will cause excessive high side pressure, quik was to check is use a house fan and put it against front of ttruck blowing into radiator and see if a/c getts colder
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 06-19-2004, 09:29 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Did you by any chance change out your crank pulley? I put an underspeed unit on my truck and the A/C was warm at idle and fine when moving. There wasn't enough RPM's to make the compressor happy.
Old 06-20-2004, 09:32 AM
Thanks alot all.
Old 06-20-2004, 09:38 AM
Re: Re: 2001 2500 HD blows hot air while idoling
Thanks alot all.
or check this out....
http://www.automotiveforums.com/vbul...d.php?t=244030
2nd entry..... i was unaware of this. might be related to your problem.
