Old 06-19-2004, 12:06 PM
d5c d5c is offline
97 tahoe water pump replacement
I have to replace the waterpump on a 97 tahoe. Are there and suggestions on how to get the fan assembly off the pump itself? Does anyone know the size of the nut on the assembly?
Old 06-20-2004, 07:39 AM
Jeremy-WI Jeremy-WI is offline
Re: 97 tahoe water pump replacement
I think I used a 1 7/16 inch wrench, but not positive. You can try a strap wrench on the fan pulley.
Old 07-06-2004, 08:59 PM
CrashH60 CrashH60 is offline
Yeah, leave the belt on to help hold the pulley in place and use a strap wrench to unscrew the fan assembly. Good luck.
Al
Old 07-07-2004, 08:22 AM
Ketch Ketch is offline
Al
I don't know about using a strap wrench - I bought a special pulley holding tool. I know its late in the game for original post but for those looking to do this job here's what worked for me:
I purchased the pulley hold tool from Oreilly Auto parts store - like $21 something but worth it as this is the most effective way to hold the pulley while you loosen the nut behind. I used a big crecent to turn that nut as it gave me the leverage.
The pulley tool looks like a giant pair of scissors but is design specifically for this engine. It holds onto two of the four mounting bolts on the front of the pulley while you loosen the nut.
Old 08-20-2004, 02:51 AM
giffo giffo is offline
I made a pulley holding tool simply by cutting a 16" length of 1/8" steel (I used a piece of old bed rail angle) and drilling two holes at one end, on 1-7/8" centers. I then bolted this on with two of the pulley fastening bolts, and turned the large nut with a crescent wrench.
The 16" length was chosen because that enabled the end of the "holding tool" to bear against the chassis while I used the (12") crescent wrench.
Old 09-07-2004, 06:37 PM
glenncof glenncof is offline
I just replaced the water pump on a '97 for the second time. OEM lasted 76,000 miles. Kragen's chinese (new) only lasted 34,000 but had lifetime guarentee and was replaced free.
Sears strap wrench on the pulley and I used a 10" pipe wrench (plumbing tool) on the fan.
Please note: Carefully re-thread fan after replacing pump. Threads are fine and you DON'T want to cross thread.
