Old 06-19-2004, 12:38 PM
JKooshTJ JKooshTJ is offline
Unhappy 1988 Cherokee BUZZER WON'T SHUT OFF
A few days ago, the buzzer went off when I inserted the key. The only problem is that it never went off after the initial engine start and it continues to go off constantly. Any advice would be great! Thanks!
Old 06-19-2004, 10:30 PM
GPN 05 GPN 05 is offline
Re: 1988 Cherokee BUZZER WON'T SHUT OFF
You have a bad switch or fuse... power is going through the fuse box after shut off for something.... check your accesories or even your fuse wires.... busser will eventually go off
Old 06-20-2004, 12:09 PM
I checked the switch for the door, and that had nothing to do with it, so I removed the buzzer from the fuse box. I'll get a new buzzer unit and check to see if that's the problem.
