Old 01-24-2002, 12:21 PM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Potential hybrid?
I have a 99EX, of course with a D-series motor in it. I know plenty of people have documented or at least heard of the LS or CRV frankenstein engines. Is there any way I can make my motor into DOHC without changing the block or putting in a whole new engine?
C:grey:
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 01-24-2002, 12:31 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
I don't believe that you can make your SOHC into a DOHC ... none of the D series engines come with DOHC so the only way is to have a B series head ... and swapping a B series head onto a D series block cannot be done ...
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 01-24-2002, 12:52 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yes there is a d-series dohc . Its called zc Anyways u can't mix d-series with b-series. SO just remember that
Old 01-24-2002, 01:18 PM
Forgot about that ... 'my bad?
Thanx mellowboy ..
Old 01-24-2002, 01:25 PM
mellowboy's Avatar
Thanx mellowboy ..
No problem
Old 01-24-2002, 05:28 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Just buy a ZC and drop it in. That's all the hybrid you need. I don't even think the ZC head will bolt onto other D series engines - anyone want to confirm or deny?
Oh and for the US guys... there is a D16A DOHC which came out in Aussie CRX's in '90 and carried through into the 5G Civics. But it was just a ZC with different engine code.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 01-24-2002, 10:43 PM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
yep...there is also a DOHC d series in the 1g integra
Old 01-25-2002, 02:46 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The ZC head and block are sufficantly differnt that the head can not be swapped onto another D series block with out some heavy machine work.
From my memories of hunting around old Honda sites before PH, I believe its actualy closer to a B series head. (but again they are not interchangable).
Its simpler and easier to just bolt in a complete ZC.
Old 01-25-2002, 10:54 AM
Even if I did get a ZC, it's DOHC but it's not VTEC, right?
Old 01-25-2002, 11:23 AM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
you are correct, but id go with a b16a, cheap and vtec!
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 01-25-2002, 12:08 PM
Early b16a swaps are definitely cheap, but a late model b16a2, from what I've seen, costs almost twice as much, if not a little more, so it's pretty far from cheap, but I guess cheapness is relative. Anyway, thanks for all the feedback, y'all.
C
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 07:30 AM
