Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-19-2004, 11:31 AM
rodgerturner rodgerturner is offline
99 Venture keyless programming help
Does anyone have the instructions to program a keyless remote w/sliding door for the 99 Venture?
thx
RT
Old 12-29-2004, 08:25 PM
jdb528i jdb528i is offline
Send a message via MSN to jdb528i
Re: 99 Venture keyless programming help
Hello!!!
try to open you keyless remote and follow instruction there.
Old 12-31-2004, 01:44 PM
stomana stomana is offline
Talking
I just programmed a remote for my 2001 Venture over the weekend using the following instructions, which I've copied and pasted from another post on this forum. I bought the remote on e-bay, it reportedly came from a 2003 Venture, and was the two-button variety without the panic or power door buttons. I don't know if there are any cross-functional problems with other styles of remotes, or with remotes from other model years. Here are the instructions:
Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased.
1) Remove the key from the ignition cylinder
2) Remove the BCM PRGRM fuse from the fuse panel
(The fuse panel is located to the right of the dash panel, just inside the passenger door. The owner's manual had a table listing the position of the BCM PRGRM fuse...as I recall there was at least one other fuse with "BCM" in its name, make sure you locate the correct fuse.)
3) Close all the doors
4) Close the liftgate
5) Turn the ign lock cylinder to the ACC. position
6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second
7) Open and close any door
Achim will be heard when the system enters the BCM programming mode
IMPORTANT!
After 7 seconds a chime may be heard confirming successful synchronization. It is necessar to wait approximately 14 seconds for a second chime that will confirm successful programming.
(I heard the first chime at 7 seconds, but didn't hear any subsequent chimes. Remote still worked, though.)
8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds
9) Repeat the previous step on each additional transmitter to be programmed.
10) Remove the ignition key from the ignition cylinder
11) Install the BCM PRGRM fuse back into the fuse panel.
This worked for me on my 2002 Chevy Venture. I got it from a post from a 1999 GMC post.
IMPORTANT!
Old 01-04-2005, 02:52 PM
spider22's Avatar
spider22 spider22 is offline
I used the same instructions, I did not always have the chimes that it states you will but it worked just the same.
