Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-19-2004, 12:25 PM
Crippy's Avatar
Crippy Crippy is offline
Prelude loss of power ??
a friend of mine just bought a 98 prelude vtec , it already had cai, exhaust , 18" rims and some cams with cam gears ... however he still is unsure about the brand of cams and gears used ... anyways he told me about this and i was thinking that this car should get up quite nicely , but it doesnt ... it rides pretty well , but no where near as good as i thought it would with those mods...you can barely hear a change in engine note as the vtec engauges ... what im getting at here is , should he get a vtec controll and have these things tuned , or does he need a header , or what do you guys think is causing this problem ?? ...
2001 GSR ,
94 jdm b18c sir-g swap , i/e !!
Old 06-19-2004, 03:48 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
its probably the cams.
have him bring it to a shop to get tuned.
Old 06-19-2004, 04:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
check the timing of those cams
Team Lonely Drivers
Old 06-19-2004, 06:24 PM
SiGNAL748's Avatar
yeah, they might be retarded
Old 06-20-2004, 12:37 AM
Crippy's Avatar
Re: Prelude loss of power ??
how would they tune em if they dont know what the specs are on them ?? and wouldnt you need valves and springs with the new cams ?? i know i did ...also , what is the normal vtec crossover point on vtec ludes ??
2001 GSR ,
Old 06-20-2004, 12:56 AM
what if the cam gear slipped and your cams are retarded fully. just make sure they are at stock timing because stock cams at stock timing should make less power then aftermarket cams at stock timing
Team Lonely Drivers
