Old 06-19-2004, 05:54 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Bad or going bad turbo?
96 spyder GST 4G63 stock turbo... go to cardomain page for full list of mods..... I have been getting oil in my intake... IC to throttlebody... not in great amounts but enough that the intake manifold is getting carboned up... Is this a sign that the turbo is on its way out? I still run about 6-7 second 0-60 and the factory boost guage still boosts up. I did put in a fuel filter in the line going from the valve cover to where the BOV dump tube is and no oil is collecting there... Any help would be greatly appreciated...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-19-2004, 02:50 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Bad or going bad turbo?
The lines that go to your stock intake (PCV/VC) will leave oil as you described, enough to where it's wet and dirty. If those are still hooked up, you don't have a problem.
Old 06-20-2004, 01:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
I'll agree and say its probably fine. When you have ad oil seals you usually know it. HEre is a pic of my M14 that is leaking oil like a champ, 3rd pic down:
http://www.posracing.net/to4r.html
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-20-2004, 02:14 AM
joemathews's Avatar
joemathews joemathews is offline
BTW the fact that your factory boost gauge is working means nothing about your turbo's condition. It isn't a true measure of boost, just an interpolation of what your boost should be. You should pick up an aftermarket boost gauge for $30 (used)...you will definitely get good use out of it.
Old 06-20-2004, 11:27 AM
Thanks for the info.... I know I need A real boost guage cause I have a MBC just wating to be put in.... The PCV isn't getting a lot of oil through it I just don't know where the oil is coming from. I just don't like the fact that it's getting into the intake mani and carboning it up... I have loss of power from it and I know everyone will agree that loss of power SUCKS..he he kinda like getting married!!!!!LOL Thanks!!
Old 06-20-2004, 12:03 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: Bad or going bad turbo?
holy shit thats a small turbo!! lol can i borrow it
Old 06-20-2004, 10:14 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I do not think that the turbo is the problem, for sure...its going to suck in anything that comes its way thru the intake housing. This is most definitly an issue with seals or pipes pre-turbo. Oil in your IC pipe? Thats wierd...maybe its grease and mud-crap from the road if you hit a puddle, or just moisture build-up...?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 06-21-2004, 01:35 AM
AF - Advisor
It is very common to have oil in your IC pipes, in your intercooler, BOV, throttlebody, and intakne manifold. Stock cars always have it. My valve cover is vented to atmosphere, so I dont have a problem with this. ITs a lot harder to clean out a 24x12x3.5 FMIC than it is to clean out a stock SMIC
Kevin Jewer
Old 06-21-2004, 06:00 PM
Oil in the lines is common? Isn't that bad for the intake manifold and such? I am for sure positive that it is oil and not road crap or the like...
Old 06-21-2004, 07:30 PM
JoeWagon's Avatar
Banned
Yes, because the stock setup has oil lines spitting into your intake pipe, so they go ALL THE WAY through your intake, turbo, intercooler pipes, intercooler, TB, manifold... It's so oil doesn't spill onto the ground, which would make bunny huggers angry.
Old 06-21-2004, 09:03 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
damn bunny huggers... ya i think it is normal too. i wuoldn't get too worked up over it. wait untill you have to literaly dump it out of your SMIC, then you may have a problem...
Old 06-22-2004, 02:12 AM
AF - Advisor
In fact its so normal, there is a vfaq for how to clean the oil out of your intercooler . Is even considered one of the "free mods" because it can make a noticeable increase in power (oil kills the heat transfer capacity of the IC).
Kevin Jewer
