Old 06-19-2004, 03:51 AM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
stroke or not?
i have a b18b and i am going to build the engine, i am having trouble deciding whether or not to stroke the engine. i am planning to run about 12 psi daily and 18 on the track.
Old 06-19-2004, 07:07 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
are you going to sleeve the block ? what exactly do you plan on doing to the motor ?
Team Lonely Drivers
Old 06-20-2004, 05:35 AM
i plan to get golden eagle sleeves, je low comp pistons, titanium valves and springs, port and polish, turbo cam, and forged rods, basically i want to build a very strong motor.
Old 06-20-2004, 07:02 PM
well if you stroke the motor it wont really affect the reliability, it will increase your tq output.
i think its all of a matter of preference
Team Lonely Drivers
Old 06-24-2004, 08:57 AM
ciVTEC94 ciVTEC94 is offline
Send a message via AIM to ciVTEC94
Re: stroke or not?
what exactly does stroking mean, how hard is it to perform?
thanks
Old 06-24-2004, 01:26 PM
boosted331 boosted331 is offline
Re: Re: stroke or not?
thanks
It means putting a new crankshaft in the motor with a longer throw, for more engine displacement.
IMO it's a waste of time in a honda. You're going to make way more torque than street tires and even slicks will be able to handle if you run a large turbo and a stock displacement motor. Adding a longer stroke will just inrease low end torque and decrease your motors ability to rev, which is how hondas make their power. I have seen B16's make over 600 wheel horsepower with a solid powerband, and if they can do it with a 77mm stroke you can do it with an 89mm stroke.
Old 06-24-2004, 02:05 PM
stroking doesnt decrease your ability to rev. ok look at it like this, you got a stock b16 8200 redline, then you got a ls 6800 redline. and the ls has a longer stroke to it doesnt have the ability to rev, according to you.
but you put that vtec head on that ls and what now the new redline on the ls stroke with a vtec head is 8200. but if the stroke decreases its ability to rev then how coem the new ls motor now has a 8200 rev limit, it should be only able to go to 6800, according to you.
stroking changes the powerband in a motor, not the ability to rev. so maybe hte new peak is lower then it was before so you dont rev any higher because its a waste.
when lots of people talk about stroked motor, they get confused between ability to rev and the change in the powerband
Team Lonely Drivers
Old 06-24-2004, 02:34 PM
Re: stroke or not?
Sorry if I wasn't 100% precise on what I meant, Mr. Smartass, but I'm sure anyone with half of a brain could figure out what I meant
Old 06-24-2004, 03:43 PM
Re: Re: Re: stroke or not?
[quote=boosted331]decrease your motors ability to revQUOTE]
when you say that, it sounds like when you stroke it, you decrease the motors ability to rev. that in no way sounds like it says you can rev just as high but your power band might be lower.
Team Lonely Drivers
Old 06-25-2004, 04:44 AM
blacksi_r blacksi_r is offline
Re: stroke or not?
it does actually throw a rod rod or put a piston through a wall on your stock stroked motor at high rpms and youll know what i am talking about.
