Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-19-2004, 01:31 AM
Kang114's Avatar
Kang114 Kang114 is offline
removing/applying emblems
hey, i just got some new red jdm style honda emblems and im wondering how i should go about removing my old emblems and applying my new ones. thanks.
Old 06-19-2004, 12:01 PM
dbebesi's Avatar
dbebesi dbebesi is offline
Re: removing/applying emblems
they are held on with a silicone glue, and two guide pins. the easiest way, would be to heat up the old emblems with a blowdryer (for a while), and pry gently at the edges with a small screwdriver, being careful not to apply too much pressure. work your way around until it becomes loose. to put the other one's on, apply some sort of all weather silicone or adhesive and push it on there. i would use goop, or a high rated silicone. good luck, and let us know how it turns out.
Old 06-19-2004, 12:53 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
it's really tedious and takes a lot of time to get all the glue completely off without ruining the finish. similar to removing window tint.
Old 06-19-2004, 03:54 PM
viet_lude's Avatar
viet_lude viet_lude is offline
Send a message via AIM to viet_lude
i hav used this spray solution called goo gone
it works i guess
Dis_Boi
I like rice.(as in the food)
1. Ricer Any oriental import(not always) car that has been modified for no real performance gain.
(Ricer: car with no engine mods, a body kit, and possibly stickers. Made to look fast.)
Old 06-19-2004, 07:43 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
My 'H' emblem came right off after a light bout of brisk nudging from a screwdriver. No harm done to the finish.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 06-20-2004, 08:33 AM
dbebesi's Avatar
the gunk will come off really well with brake cleaner.
Old 06-20-2004, 04:51 PM
Kang114's Avatar
so i have to take my old ones off, then clean the area right? okay but do i need to buy more goop adhesive to stik it on or could i just use the adhesive thats already comes on the back of the new ones???
Old 06-20-2004, 06:08 PM
del del is offline
móddə rąytər
leave it out in downtown chicago parked on state street. someone will yank it off for ya. at least that's how mine was taken off........bastards!!
get some heavy duty double sided tape. and you can use that to stick it on. make sure it's weatherproof coz if it's not, it'll surely fall offf once it rains.
Old 06-20-2004, 07:09 PM
ca2822 ca2822 is offline
Send a message via AIM to ca2822
Are the emblems on the 4th gen ludes stuck on the car w/ just glue? Cuz i wanna take em off but i wanna make sure theres not gonna be a hole behind the emblem when i take it off.
Old 06-20-2004, 10:50 PM
dbebesi's Avatar
there is two guide pin holes. at least any honda ones i have removed has had them. also IMO double sided tape doesn't work well. heat will make it swell right off, plus it'll be raised up. a good all weather adheasive is the best route.
