Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 06-19-2004, 01:22 AM
mindfrost82 mindfrost82 is offline
Send a message via AIM to mindfrost82 Send a message via Yahoo to mindfrost82
Squeal from front passenger wheel (possibly brakes)
I have a '97 Dodge Intrepid. After driving the car for a while I notice a squeal coming from the front passenger side wheel. I believe it's the brakes. It makes the noise without applying the brakes. When I apply the brakes, the squeal gets louder then goes away. Once I let off the pedal it starts again. If I'm driving down the highway it doesn't do it. It does it in normal city driving. When I first start driving it for the day it's fine, then after going a few miles it starts. It made the noise before, and I had the pads replaced and everything looked good, but it still makes the same noise. I'm not even sure if it's the brakes.
Any suggestions on what it could be or how to fix or diagnose the problem?
Old 06-21-2004, 02:13 PM
Black95 Black95 is offline
The sound of the noise will tell you what it is. It could be brakes high pitch squeal. It may also be a bearing - more of a rubbing or humming sound.
Old 06-21-2004, 02:21 PM
It's more like a squeal. I read somewhere that if it's a bearing that the noise would change or go away when you turn the wheel, and this noise doesn't change. I got some suggestions from another board I'm gonna try.
If anyone here has any suggestions, please post them.
