| Off-Topic Talk about anything other than cars. |
I am getting my 420a rebuilt and it is completely out of the vehicle, what are some suggestions for upgrades that i should consider and or available. Any feedback is appreciated.
Re: I took out my motor...what should i do?
BTW, the mechanic said he would bore out the motor so that it would be about a 2.2L instead of a 2.0L, is this kind of increase possible and if so how much extra HP will it give me?
knife edge cranck, forged rodes & pistons, new cams,valve springs, p&p the head, or just say fuck wasting all that money and swap a 4G63T 1'st gen so you dont have to worrie bout crank walk
which upgrade(s) will give my car the most power?
Re: Re: I took out my motor...what should i do?
your not goin to get a 4g63t motor in that car without spending 5-6000 on it... then the motor is still stock, so if he spends the 5-6000 on the 420a then he is a hell of a lot faster!!! |
RST said it, for the money 4g63t is out of the question. build and boost the 420a.
true....
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE ![]() ^^^ hehehe 2000 Ford F-250 boostin' 30 psi 1997 Lexus ES 300 2000 Mazda 626 1999 Mazda Protege 1991 Geo Storm boostin' 10 psi 1998 Eclipse GSX boostin' 16 psi 1991 Oldsmobile Cutlas Calais |
get it bored out forged pistons, rods, crank. lighten the flywheel so it will rev faster. port and polish the head and intake exhaust manifolds. 3 angle valve job. the list is endless
speed is money, how fast do you want to go?
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
you could get it resleved, cams, bigger valves, valve springs....
Are you even planning on turboing the car?
For Sale 98 Eclipse GS, 5 spd |
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
best for the buck would be a turbo.. haha. for the money you'd be spending to do half the stuff these people mentioned you could easily turbo it. just save some cash up and have at it. anything will help. Good luck
V8's are like tampons, every pussy needs one! |
yhe still needs forged internals to run boost right or is that only if u plan to run high bosst
it should hold if you just run vary little boost, nothing crazy. i've been told 5 psi.
