Old 06-18-2004, 09:36 PM
cody07 cody07 is offline
transmission leak
I Have A 2000 Silverado X-cab 4x4. I Noticed A Leak Coming From A Tube That Seems To Be Attached To The Transmission. Have Checked The Fluid Level And Seems To Be Fine. Does Anyone Know Where This Tube Goes And Why It Would Be Leaking? The End I Can See Is Clamped To The Top Of The Transfer Case.
Old 06-19-2004, 08:17 AM
Redneck_Cadillac's Avatar
Redneck_Cadillac Redneck_Cadillac is offline
tube
the tube is a breather hose for the transmission. the tranny is either slightly overfilled, or got hot enough to puke a small amount of fluid out.....(????)
depending on mileage....it may be a detent issue, or something with the pump........
I haven't, nor ever will claim to know everything about cars..... but a big f*cking hammer can fix most problems.....
Old 06-23-2004, 10:40 PM
Garys99-3/4ton Garys99-3/4ton is offline
tranny or transfer case?
Is the fluid red or blue? I have had a problem with my transfer case leaking which does have a breather tube clamped to the top of it. It's a long story but, there are actual cracks wearing through my transfer case and at first I thought it was coming from the breather tube. If it's blue, transfer case lube, I will elaborate.
Old 06-25-2004, 09:41 PM
FLUID IS RED. CONTINUES TO LEAK ABOUT A TABLESPOON OF FLUID EVERY TIME I PARK MY TRUCK. I HAVE CHECKED THE LEVEL SEVERAL TIME AND IS NOT OVERFILLED. STARTING TO GET A LITTLE CONCERNED.
Old 08-08-2004, 12:28 AM
stubbornmike stubbornmike is offline
Re: transmission leak
try a transmission flush trans fluid foams as it deterates or if it got air in the pump it will bubble sounds like that the issue..
