rb25de trans w/ rb26dett engine???
hello
I searched but could not find a yes or no answer. its probably no but dose anyone know if its possible to use the rb25de transmission with the rb26dett. any help is greatly appreciated. thanx |
You have to, unless you want to convert your 240 to 4WD.
Re: rb25de trans w/ rb26dett engine???
so their is no difference between the rb25det transmission and the rb25de transmission.
thanx |
That I don't know, there shouldn't be.
You Can Keep The Rb26dett Tranny.....although The Extra Weight Isn't Worth It Unless You Have A R34 6 Speed.
You Pull Out The Front Shaft Yoke And Seal It Then You Disable All The Electronics To The Transfercase. |
In other words it's easier to get a RB25 tranny. :-P
Yes---this is what the guys as BBE said too.....
You dont even need to disable the electronics, without the computer from the rear of the car, the front wont work at all.
Doesnt it depend on what year engine you get? I think the later model GTRs had a Pull type clutch and GTSs had Push? or is the Bell housing Seperate?
Easy for you to use an rb25 tranny and you will also need the rb25 oilpan.
![]() Ain't this the pretiest motor or what? ![]() Fines are the fee you pay for the privilege of driving as fast as you want
the rb25det tranny can hold more of a beating considering its more of a bulkier tranny
thanks for all the replys I greatly apprecite it
thanxs |
Nice conversion 240Z, first time I've seen that.
I am imagine there is at least a small difference between a gts2.5t tranny and the n/a 2.5 tranny....Probably geared to be more torquey since the engine has less overall power...but who knows? I would look online (esp jap sites) for specific ratios.
And you will not want the RB26 tranny...so don't bother dreaming about AWD. AWD is for subis and skylines...not a 240.
The Rb25de And Rb25det Trannies Are Different...... The Rb25de Tranny Is The Same As The Rb20.
And There Are A Couple Awd 240sx's Running Around Now So Don't Talk Smack Awd Has A Ton Of Benefits..... And The Rb26dett Tranny Is Stronger Than The Rb20 And You Can Disable The Transfer Case. |
