Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-18-2004, 09:37 PM
pnoiSR20 pnoiSR20 is offline
Wat is VVTL???
I have been researching around for an SR20 motor. THey all mention about the new VVTL. Wat exactly is that???
Old 06-18-2004, 09:44 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
I think it's Variable Valve Timing Lift, but anyways, it's a feature they had on the S14 and S15 SRs, it adds a little power in the top end by changiong the valve timing, I hope you know what that means.
Old 06-18-2004, 10:12 PM
Re: Wat is VVTL???
I hear it is Nissan's answer to Honda's VTEC.
Old 06-18-2004, 10:45 PM
logik23's Avatar
Banned
Yeah, but pretty much all companie shave it now, it's either like VTEC, VVT, VTC, VVTL, etc.
Old 06-19-2004, 01:35 AM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
Re: Wat is VVTL???
it's like VTec pretty much, the camshafts change in accordance to RPMs to take in the right amount of air intake. What this means is the maximum amount of power for each RPM.
and it's VVTC, for variable valve timing chain, not VVTL
Old 06-20-2004, 09:09 PM
wingsofwar's Avatar
wingsofwar wingsofwar is offline
Send a message via ICQ to wingsofwar Send a message via AIM to wingsofwar Send a message via Yahoo to wingsofwar
Vtec doesnt change the timing it changes the lift by using different cam lobes at certain RPM. VVT changes duration of the valve openings without changing the lobe profiles. Ultimatly VVT and Vtec almost accomplishes the same thing, but they do totally different things.
Old 06-20-2004, 09:12 PM
ghetto7o2azn ghetto7o2azn is offline
vvtl is in the celica
Old 06-20-2004, 10:07 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Wat is VVTL???
It sound like one more thing to go wrong if you ask me.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 06-25-2004, 09:34 PM
Re: Wat is VVTL???
Ok thanks guys.
Old 06-25-2004, 11:09 PM
freelunch's Avatar
freelunch freelunch is offline
Does VTEC allow for different 'stages'? Like at high RPMs it runs the motors like a race motor, and scales it back at lower RPMs. Or is that i-VTEC?
Old 06-26-2004, 12:41 AM
240SX Guy
Re: Wat is VVTL???
It uses different lobes on the camshaft proportional to engine rpm to maximize fuel efficiency.
-Cory
12.6@122mph
Old 06-27-2004, 05:12 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: Wat is VVTL???
VTEC is either "on" or "off". "High lift" or "low lift".
Nissan's VVL is a 3-stage system with the intake cam and the exhaust cam switching as different times.
Stage 1: intake cam= low lift, exhaust cam= low lift
Stage 2: intake cam= high lift, exhaust cam= low lift
Stage 3: intake cam= high lift, exhaust cam= high lift
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 06-29-2004, 09:20 AM
SHO411's Avatar
SHO411 SHO411 is offline
Re: Wat is VVTL???
Sounds fancy but most ppl putting serious power tend to diconect all the above. Have no idea why, but vtec, and vvtl are never used when trying to produce big power well except for the RB and 2JZ, and any other big engines but on the smaller ones they take them off. Any one knows why????????
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
Old 06-29-2004, 09:55 AM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
Re: Wat is VVTL???
when you change the cams you don't have Variable Valve Timing anymore simple as that
OK thats it
time to explain the different types of Variable Valve timing
This is the Variable Valve timing that changes the lobes.
Which changes the cam profile
The other type is VTC which is a helical gear at the end of the cam shaft which can advance or retard the timing of the cams.
Both systems are operated by oil pressure. The oil pressure turns the gear to increase valve overlap.
The one on the cam lobe increases the duration the valves are open.
good ey?
Qualified Automotive Engineer
