Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-18-2004, 04:35 PM
jobwanter jobwanter is offline
Unhappy stanger problem with my 96 neon
my car is more than 35 mpg before. but recently it dropped to 16 mpg.
i changed the tires and cleaned the air filter. but no improvement.
so i guess its sparks may need to be changed. when i was changing the sparks, i found engine oil in the 4th spark.
any suggestions?
thanks.
Old 06-18-2004, 05:25 PM
Re: stanger problem with my 96 neon
any suggestions?
thanks.
I found some ppl have the same problem as mine:
Question: 1996 Dodge Neon DOHC mileage: 84000. Hi guys. I was changing my spark plugs today and when I pulled out one the old plugs, it was covered in oil. Is this normal? I don't know too much about cars but none of the other cylinders were like this? What do you think?
Answer: It would appear from what you described that the rings and/or valve stem seals have failed in the cylinder with the spark plug that was covered in oil.
Follow-up from viewer: On theses particular cars the plugs are down in the head a good ways and if the valve cover gasket is leaking it will leak down into these holes! Try replacing the valve cover gasket first before spending a lot of money on diagnostics for internal engine damage!
Old 06-21-2004, 08:08 PM
seniorbigs seniorbigs is offline
Common problem, replace the valve cover gasket and spark plug well gaskets.
