Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 06-18-2004, 01:32 PM
jaysheard jaysheard is offline
Send a message via AIM to jaysheard Send a message via MSN to jaysheard
idling
my '87 toyota pickup 22R-E usually idles anywhere from 750 rpm up to close to 2,000 rpm sometimes, i found out what the problem is but im not sure of how to fix it, the accelerator cable linkage on the TBU is sticking, is there anything i can do to grease this up perhaps?
Old 06-18-2004, 10:06 PM
natenelsen natenelsen is offline
Send a message via Yahoo to natenelsen
Re: idling
are you sure it is the cable that is sticking and not the throttle plat itself? Remove the cable from the t-body and check to make sure it is the cable that is sticking. A lot of times I have seen this and it is actually the throttle plate that gets carbon and crud built up and starts to stick. get a good brand of cleaner like k/w gorrilla or even b12 chemtool to clean out the t-body and make sure to spray the out the passages, back of the throttle plate, the bar that holds the throttle plate and after it is all good and clean, put a littl drop of oil or two on both ends of the bar. dont use wd-40 or some other penetrating oil unless you use a drop or two of motor oil after wards, as the penetraiting oil will evap.
If it is the cable, you can try lubing it with dry graphite, but I would *NOT* use any type of grease or oil in the throttle cable, that can lead to a stuck throttle. If you cannot get the cable lubed with dry graphite, then replace it. Oh yeah, be sure to check for damage (kinks of pinches) on the cable
best of luck and write back to let us know how this turns out.
Nate
Old 06-19-2004, 09:32 AM
thanks, i'll be sure to give that a try, b/c it is really bothering me sometimes, when im driving and then go to stop at a light, and im revving at about 1,500 rpm, im also sure that this will help out my gas mileage a bit more. once again much appreciated for your help, ill get back to you on how it works out.
Old 07-02-2004, 04:12 PM
Re: idling
hey nate,
well i bought some TB cleaner and sprayed out everything, b/c it turned out that it was in fact the plate that was sticking. she purrs at a nice quiet idle of 750 rpm's now, thanks for your help,
Jay
