Old 06-18-2004, 01:30 PM
BBFAN64 BBFAN64 is offline
Timing Belt
In reviewing other posts I am suspecting that my timing belt has lost some teeth as my 93 Escort LX Wagon won't start but is getting fuel and spark. My question is if I pull off my valve cover and crank the engine, if the values aren't moving does that indeed mean a timing belt issue? Thanks in advance for your input.
Old 06-18-2004, 01:41 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Timing Belt
First thing I'd check in ur case. Hope you don't have an interference motor.
Old 06-18-2004, 08:10 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Timing Belt
Yes, if the valves aren't moving then the timing belt is shot. You didn't say what size your engine is but most of the newer Ford 4 cylinders are interference engines so you probably bent a number of valves if you were running the engine when the belt broke. If so you will need a new head (used one will be OK and cheaper too.)
Old 06-22-2004, 06:33 AM
Re: Re: Timing Belt
It is a 94. Nope, not an interference engine. Sure enough, it was the timing belt. About 8 ribs were broken off. Put on a new belt and she started right up !! Yahooooo.
Old 06-22-2004, 05:26 PM
brindfan brindfan is offline
With all these timing belt breaks I keep reading about, may I remind you that the belt SHOULD be changed EVERY 60,000 miles. This is something you should NOT ever let slide.
