Originally Posted by CalMar
My 1995 Pathfinder has developed a fuel odor problem from the rear of the car, No it's not a leaking fuel tank or leaking anything... It, some what go's away as fuel is used up, It's worst just after filling the car. Any ideas??
This was my solution for identical problem. Drop protector plate under the fuel tank, and you will probably see what appears to be a spot that is dark & greasy dirt on the bottom of the tank. Clean it down to the shiny metal and inspect closely. You may find two or more small circles in a row. These I believe are the rivets that anchor the gas tank baffles, or some other bracket in the tank. You may notice that one or more of them seem to weep - not drip - moisture (fuel). Does not seem like much, but as I found out, it was the source of the heavy fuel smell.
Before investing in a new tank, I purchased a fiberglass repair kit for fuel tanks from the hardware store. You will have to also purchase a moisture proof epoxy product to stop the weeping prior to using the repair kit (I used a product called "Waterweld" from the same hardware store - comes in a small tube for a couple of dollars). Once this has hardened and the weeping has stopped, apply the fibrergalss repair according to instructions. I applied two kits over two consecutive days over all of the rivets whether they were weeping or not just to be on the safe side. Did this a year ago, and have had no problems since.
Good luck.
