Old 06-17-2004, 07:03 PM
chevysrule chevysrule is offline
Recalls?
i own 1990 chevy lumina. im wondering if u guys have heard of any recalls. i was notifited today that there was a recall on my brake switch which is good then i get it fixed for free. Just wondering if there is anymore. i live in canada and my car is a 3.1 v6 euro car! thnks
Old 06-19-2004, 02:27 PM
mikeb55421 mikeb55421 is offline
a web site you can check out that has recall information is www.alldata.com. you can enter in your make, model,and year and it will tell you about all your recalls
Old 06-20-2004, 03:47 PM
Jay Beezy Jay Beezy is offline
Re: Recalls?
Alldata.com tells you the recalls, but they don't tell you anything about it specifically. I saw one that might pertain to me but I wasn't sure what exactly it was about.
Old 06-20-2004, 04:38 PM
your best bet is to find a lead on recall then call a local dealership, they could tell you more
Old 06-20-2004, 07:16 PM
cadgear's Avatar
cadgear cadgear is offline
Re: Recalls?
You can go to MyGMlink.com, register your VIN and then you have access to the recalls. Takes a bit of time though.
Old 06-22-2004, 04:45 PM
ya i ended up calling the local chevy dealer here in bc and the only recall on my car was the brake switch, i just dont know what it controls like if it really something i should get fixed.
Old 06-23-2005, 01:36 AM
Taz202 Taz202 is offline
Re: Recalls?
I had the body mounts replaced, if that's what they are called, I'm not sure now. They are located in four places under the engine. The rubber can get all hard and sometimes as was my case, they pulled through the frame letting the engine partially fall out. I had it fixed at a local garage but continued to hear knocking coming from the front end. I finally took it to a chev dealer. That's when I found out they were recalled for that problem.
Old 06-23-2005, 06:01 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Re: Recalls?
That's always fun.
The first gen Ford Tarus and Sable had a lotta problems with that, the two rear engine cradle (subframe) mounts would break, and the cradle would drop, leaving the driveline almost dragging the ground and very little steering control. Instead of steering the wheels, the rack was just shoving the whole cradle side to side. This started happening when these cars were just 6-8 years old.
But I guess given enough years and corrosion, it could happen to any FWD car. They all have the same arrangement, with the whole driveline sitting on a cradle mounted to the unibody with four large bolts and bushings.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-23-2005, 06:02 PM
Re: Recalls?
Here's another resource:
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
...empty gun rack.
