Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-17-2004, 05:28 PM
thoot12 thoot12 is offline
rear view mirror
My rear view mirror seams to be losing its fluid. I am looking for a solution or replacement part.
Old 06-17-2004, 10:10 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: rear view mirror
http://cgi.ebay.com/ebaymotors/ws/eB...category=33699
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 06-18-2004, 08:53 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Common. Be aware that the early LS's WITHOUT the compass in the mirror will NOT accept the newer mirror with a compass.
I replaced mine with a OEM unit from www.fordpartsnetwork.com I think it was about $85.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 06-21-2004, 06:57 AM
Ford Motor just replied with a quote of 88.99 for the mirror.
Thanks,
Trey
Old 06-21-2004, 11:30 AM
How difficult will the installation be?
Old 06-21-2004, 06:22 PM
Quik_LS's Avatar
very very easy - spend some time looking at your current one.
see my mean LS
Old 06-22-2004, 07:28 AM
CGGorman's Avatar
The only thing not included with the replacement is the wedge that mounts to the windshield. My old one pulled off and the new one slid on. Other than plugging in the power lead, that's it.
Old 06-22-2004, 08:34 AM
Thanks Guys!!!
Trey
Old 07-02-2004, 02:36 PM
01 Lincoln LS 01 Lincoln LS is offline
Send a message via AIM to 01 Lincoln LS
how do i set the compus on my merror. It needs to be recalibrated but it doesn't say anything in the manual.
Old 07-02-2004, 04:32 PM
Quik_LS's Avatar
manual page 85
AUTOMATIC DIMMING INSIDE REAR VIEW MIRROR
Your vehicle is equipped with an inside rear view mirror which has an auto-dimming function. The electronic day/night mirror will change from the normal state to the non-glare state when bright lights (glare) reach the mirror. When the mirror detects bright light from front or behind, it will automatically adjust (darken) to minimize glare.
Do not block the sensor on the backside of the mirror since this may impair proper mirror performance.
Ensure the mirror is pulled down low enough to prevent visibility interference with the overhead console. The mirror support arm has two pivot points which lets you adjust the mirror UP or DOWN and from SIDE to SIDE.
Press the control to turn the mirror on or off.
The mirror will automatically return to the normal state whenever the vehicle is placed in R (Reverse)(when the mirror is on) to ensure a bright clear view when backing up.
ELECTRONIC COMPASS (IF EQUIPPED)
The compass reading will remain accurate during most driving conditions. Unknown to the driver, the compass is continuously recalibrating due to magnetic fields and subtle, slow changes in vehicle magnetics which can occur over the life of the vehicle.
The compass reading will remain fixed when significant levels are experienced (such as steel bridges). The compass will return to normal operation upon leaving the magnetized area.
If highly magnetized items (such as magnetic mount antennas) are placed very near the compass the display will change to “C” for 15 seconds, then display all segments until the magnetized item is removed. If a “C” is displayed, refer to Compass calibration adjustment.
Most geographic areas (zones) have a magnetic north compass point that varies slightly from the northerly direction on maps. This variation is four degrees between adjacent zones and will become noticeable as the vehicle crosses multiple zones. A correct zone setting will eliminate this error. Refer to Compass zone adjustment.
1. Determine which compass zone you are in by referring to the zone map.
2. With the compass display turned on, press and hold the COMP side of the control for no more than six seconds until the zone selection number appears in the mirror display window. If a“C” appears repeat this step.
3. Release the COMP side of the control, then press it down again.
4. Continue to press until your zone number is shown in the mirror display, then release.
5. The display will show all segments, then return to normal compass mode within ten seconds.
Perform this adjustment in an open area free from steel structures and high voltage lines.
1. Start the vehicle.
2. Press and hold the COMP side of the control for approximately six seconds until “C” appears in the mirror display.
3. Drive the vehicle slowly (less than 5 km/h [3 mph]) in circles or on your everyday routine until the display reads a direction.
4. The compass is now calibrated.
see my mean LS
Old 07-03-2004, 01:29 AM
thank you, my manual doesn't have that map on it... ?
Old 07-03-2004, 07:51 PM
my compas never says "c" i am able to select the regon number but it never says "c" it does say something like "188ºfºc" Is it possible to drive 3mph??? When i let go of the gas i go like 8mph the slowest
Old 09-02-2004, 02:21 PM
95ragtop 95ragtop is offline
"188ºfºc" - not a good sign. If it always says this your part is garbage. There is some hope though. There is a wire harness that runs from inside the mirror to the module on the mount the fastens to the windshield. If this wire is broken or unplugged at either end the symptom you described occurs. There are other things that can cause this, but this is the only one that is repairable. The front and rear parts of the mirror are not permantly sealed together. They are held by a series of snaps. If you're carefull, you can pull it apart and check this wire harness.
Old 09-02-2004, 07:00 PM
actually its fixed, i just took it in and it was under warranty
