Old 06-17-2004, 03:53 PM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
Exclamation B18 Swap
i have a 89 civic dx im gonna put a B18 in and i was wondering if there was a web site on how to do it. as in all parts need aside from engine and tranny and axles. can i use a PG7 ecu or do i have to have a ecu out of a integ. the engine is comming out of a 90 or 92 rs. tanx for info.
For You Are Crunchy And Taste Good With Ketchup!
Old 06-17-2004, 06:05 PM
travagliante's Avatar
travagliante travagliante is offline
Re: B18 Swap
what year 90 or 92 because 90 is obd0 and 92 is obd 1. The 92 engine will be a hell of a lot more harder to wire in as opposed to the 90.
Just get a civic service manual, and a integra service manual and work out the bugs b/w connections.
You will need a mount kit, shift linkage, convert to MPFI, pg7 ecu wont work-(for a 1.6L engine not a 1.8), and some more custom parts.
SEARCH and then come back with questions
Old 06-17-2004, 06:19 PM
recycle_me's Avatar
Re: B18 Swap
i have searched theres not a ot of info on all this stuff out there. i have spent about a week looking in this forum and others along with search engines google ask.com dogpile all of them nothing.
Old 06-17-2004, 07:03 PM
slo89 slo89 is offline
Send a message via AIM to slo89
Re: B18 Swap
http://www.hasport.com/Tech/Installs...0partslist.htm that might help you some.
Old 06-17-2004, 11:58 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: B18 Swap
yeah i can get almost a complete LS swap from a 91 for $400 right now but i think im just gona stay with D-series engines, easier and cheaper to build on. This guy said he could build be a turbo kit for cheap too, about $800 i think he said.
1991 Honda Civic DX Sedan
Old 06-18-2004, 09:43 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Re: B18 Swap
sorry but ur a little mis informed...
1. the engine doesn't matter which year it comes out of. Use ur stock harness to run any year engine. if you use the 92 engine (better) you'll just need a 90-91 teg dizzy. I'm running a 98 crv b20 (originally obd2) with my dx harness.
2. yes, you'll need a mount kit, shift linkage, 90-93 teg axles, convert to mpfi (if its a dx). You can actually run a b18 off of the PM6 ecu without any problems. The wiring is identical. You can also run it off of the PG7. The 90-91 integra PR4 will be better but the PM6 and PG7 will run a b18 without problems....the o2 sensor will compensate for the greater airflow output with the b18 and adjust the PM6 or PG7 to add more fuel.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-18-2004, 10:48 AM
91civicDXdude's Avatar
Re: B18 Swap
this is all fine and all, except you're forgetting one thing. after 75% throttle, the ECU goes into open loop mode and O2 sensor input is disabled.
In other words, in the time you need the correct air/fuel mixture the most, its not there. the engine will run lean.
Use a PR4, or a chipped PM6 with PR4 maps.
Old 06-18-2004, 03:57 PM
recycle_me's Avatar
Re: B18 Swap
will i have to beat the frame out in my dx for it to fit in or will it squeeze in? thanx for the tech info it really helps.
Old 06-18-2004, 04:23 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: B18 Swap
yes for the alternator.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-18-2004, 06:24 PM
recycle_me's Avatar
Re: B18 Swap
so the only place ill need to beat in the frame is for the alt thats it? will i be able to retain my ac or is that askin too much.lol
Old 06-18-2004, 09:04 PM
Re: B18 Swap
you'll need to bend the lip on the rear cross member down where the rear mount bolts on, and depending on themotor mount kit you are using, you might have to clearance the firewall for the rear mount bracket.
