Old 06-17-2004, 03:11 PM
bov300zx's Avatar
bov300zx bov300zx is offline
Bolt Patterns
Are the bolt patterns in the head if the B18A, B18B, and B18C the same? I wanted to use an intake manifold designed for a gsr on my 91 b18a. Is it possible?
96 Honda Prlude
AEM Cold Air Intake
MSD Ignition
DC 4-2-1 Header
Greddy EVO 2 Catback Exhaust
17" Motegi Racing Wheels
Eibach adjustables
Old 06-18-2004, 02:26 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
well anything is possible, its not a direct bolt on because the botl pattern doesnt match
Team Lonely Drivers
Old 06-18-2004, 02:40 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Bolt Patterns
99% sure it will fit because all B-series manifolds are compatable.. Try taking measurements to see.
Old 06-18-2004, 06:02 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Bolt Patterns
I believe the GSR manifold is the only one not compatible with the other B-series heads. The GSR manifold has the dual-runner design and the bolt pattern is a little different. The B18A, B18B, and B16A manifolds are compatible with each other I believe.
He'll probably have to swap a GSR head onto his motor to accomplish this, which means wiring in VTEC and swapping the ECU if you want it all to work properly. Basically an LS/VTEC with a GSR head and manifold.
Personally I would just use the B18B manifold.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 06-18-2004, 01:43 PM
bov300zx's Avatar
Re: Bolt Patterns
Thanks for the info. Any recomendation for a head swap without having to spend $1500 to for a full ls/vtec conversion? Thanks again.
96 Honda Prlude
AEM Cold Air Intake
MSD Ignition
DC 4-2-1 Header
Eibach adjustables
Old 06-18-2004, 08:44 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Bolt Patterns
No, they aren't, GSR's is different.
Old 06-19-2004, 12:32 AM
boosted331 boosted331 is offline
How the hell do you figure 1500 bucks? A GE vtec conversion kit has all the shit you need (oil line, oil filter adapter plate, head gasket, dowel pins, etc), toss in your VTEC head, a new ECU and you're gravy. You can spend less than 1000 and get it done.
Old 06-19-2004, 12:50 AM
where do you guys get yoru info from, damn
b18a, b18b, b20 intake manifold are the same
b16a, b17a, and type r intake manifolds are the same
b18c is different from the rest
so a b18c intake manifold will not fit on the b18a or b's because the bolt pattern is different
Team Lonely Drivers
Old 06-19-2004, 01:58 AM
Ricochet's Avatar
Banned
Re: Bolt Patterns
Guess that 1% kicked me in the ass
