Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 06-17-2004, 02:27 PM
smokeurass's Avatar
smokeurass smokeurass is offline
octane levels/detonation
im planning on swapping the rb25det in my 240. I heard a little bit about the need for higher octane or the use of race fuel, otherwise detonation will ocur with this engine (its always the important stuff everyone doesnt keep talking about). When you guys purchase skylines from motorex, do they fix this shit or are u guys paying for racing fuel all the time, lol. Can someone please explain this a little bit more before i make a mistake. thank you
Old 06-17-2004, 03:30 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Race fuel for a rb25. If you run 93oct you should be fine. Take the car to get it tuned, they can adjust the timing, and you will be good to go.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 06-17-2004, 03:56 PM
smokeurass's Avatar
you know this for sure?
some smart ass was saying like he knew it for sure, detonation or w/e will occur if your not using like 110 or something...and THATS BAD! lol
are u in japan?
Old 06-17-2004, 04:04 PM
SkylineUSA's Avatar
Re: octane levels/detonation
Thats complete cow dodo. 110, thats some funny stuff.
Yes, 93 will be fine with an rb25 on stock boost. If you increase your boost, now then you need to get that sucker tuned.
Old 06-18-2004, 02:10 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Re: Re: octane levels/detonation
Our BP 98 here in New Zealand is equivelant or slightly less than American 93 in quality and equal rating. It is more than fine for factory or even mild mods. Make sure your timing is set to no less than 17 degs at idle. Standard I believe they were 13-15 degs. You will be or should be more than ok up to about 12psi providing you have a good fuel pump. The factory is fine if it is working properly. If it isn't get a Bosch 044 Motorsports pump fitted but RETAIN the non-return check valve!
I'm running standard pumped gas (98) here in New Zealand with my GTR and pushing 17psi of boost with 18degs timing. No detination at all.
I would however still suggest getting your Air Fuel (A/F) checked to see what level it is. It should be no higher than 11.8 under boost anywhere in the rev range. Off boost lean is ok providing it isn't higher than 15.1 ! That would be simular to cruising.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 06-18-2004, 02:26 AM
SkylineUSA's Avatar
Agreed
Old 06-18-2004, 02:53 AM
lambchops lambchops is offline
Where would you be able to get race fuel anyway ???
Also, can your engine take prolonged use of race fuel ???
We tend to use Optimax from Shell... it's also 98 octane and is the best fuel to use with the japanese imports... just a bit more expensive too...
Old 06-18-2004, 03:36 AM
SkylineUSA's Avatar
Your in England, Santa Pod should have it. Race fuel is pointless unless the car is tuned for it. You can run all day long, if you have the money.
I run Optimax in mine, but I also run 91oct(American), but I do not boost when its in the tank, for long trip I use that.
Old 06-18-2004, 04:32 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Most race fuel is old leaded aviation gas that has aged to much to be safe in aircraft.
There is a growing number of people who believe that leaded fuel will over time clog and ruin O2 sensors.
I peronsaly have yet to see any proof of it, and I even know of O2 sensor equiped cars that run perfectly fine on it, however I do some respested people who cliam to have problems.
If you do plan on running on race gas be warned, that if its leaded (it will be labled as such) you may damage your O2 sensors.
And of course you need to check on your local laws regarding the use of leaded fuel on the road, here in NZ for example it is illegal, and special unleaded high octane race gas has to be used. (again, its old unleaded aviation fuel, relabled, but its rare and so more expensive).
Old 06-18-2004, 06:36 AM
RazorGTR's Avatar
Skyline Man
Actually it is fact that it stuffs O2 Sensors. I know of quite a few cases. Also Torque performance's A/F sensor, which is a wide band O2 sensor only last 4 hrs with leaded race fuel while standard fuels it averages 200 hrs. At $800 each he's not keen to have to keep buying new one's, so he charges accordingly extra with tuning on leaded race fuels.
Old 06-18-2004, 11:43 AM
smokeurass's Avatar
....thanx a lot guys...
You dont boost at all...im planning on taking it on a trip too...
Old 06-18-2004, 03:11 PM
RazorGTR's Avatar
Skyline Man
Smokeurass define "boost". You can't and shouldn't simply wind the boost up to get more power without supporting. Not to mention the R33 has a factory boost cut of around 14psi. I honestly can't remember the cut. It is controlled by a boost control solinoid which makes trying to get around it a bit of a mission and if not done properly it WILL over boost.
Another quick fact the R33 GTS25t's have a two stage boost setup factory. It will boost to about 6 psi until around 4700 rpms then go up to about 7.5-8 psi after.
Old 06-18-2004, 04:36 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
you sure about that Vince because my 25T seems to have quite a smooth boost curve with very little step at all
Old 06-18-2004, 07:48 PM
RazorGTR's Avatar
Skyline Man
Yep everyone and even your's has a movement, some seem to be more pronounced than others.
Old 06-18-2004, 09:35 PM
tazdev's Avatar
I'm still here
guess you should know with all the work you do for Robin
