Old 06-17-2004, 01:58 PM
rwilkers rwilkers is offline
Question Chilton and Haynes Wrong about EDIS
Just picked up a 1996 Escort LX with a 1.9 Liter High Output for a project car. Has a bad idle and misfire problem and I plan on replacing the PCM and IAC. According to Chilton and Haynes, this unit uses a PCM coupled with a EDIS module and both provide a location of just forward of drivers side front strut tower. The EDIS module is NOT there, just the mounting bracket, and there is not a wiring harness connnector there either.. Any ideas? I double checked the VIN just to make sure that the year and motor type were correct.
Old 01-28-2006, 02:25 PM
hytwr1 hytwr1 is offline
Re: Chilton and Haynes Wrong about EDIS
Did you ever find them? I'm running into the same issues.
Old 01-28-2006, 09:28 PM
No, it turns out they were wrong.. Apparently some of that particular year model did not have a separte module.. All the electronics were in the ECM module under the dash behind the center console.
Old 01-28-2006, 10:25 PM
Escort_Service Escort_Service is offline
Um if theres no coil pack then your car wont run. I think your looking in the wrong spot. If your car has a PCM then why are you throwing it out? (Performance Control Module)
I think you should take another look. I have the same engine and my coil pack is there.
5.0 Mustang where would you be if I took 4 of your cylinders? In the scrap yard you ugly piece of #$?@
Old 01-29-2006, 06:44 AM
Thanks Rwilkers. That explains why I can't find it. Difficult to get to I'll bet and even more fun to find a replacement?
Escort service...We're not talking about coil pack. It's the EDIS module we are looking for.
Old 01-30-2006, 08:40 AM
my bad
Old 01-30-2006, 02:34 PM
Been there.
Old 01-30-2006, 09:00 PM
Davescort97 Davescort97 is offline
Escort guy
There is no EDIS module. It just stands for Electronic Distributorless Ignition system. The power control module is under the heater controls at the front of the console. The PCM controls the ignition system. It is sometimes called the EEC (Electronic Engine Control).
Old 01-31-2006, 03:21 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Yes the book is wrong. I also have a 96. The book includes the 96 with the older OBD1 Escorts, and thats not right. Starting in 96 Escorts went to Obd2, at that same time they used a ECM with the EDIS built into it. Your 96 is more like the 97 but minus the IMRC output. 96's also have two O2 sensors, and the book only show's one.
Your bad idle and misfire is probly not form the EDIS/ECM. They seem to last longer then the car it's self. And also, your 1.9 motor is'nt really a "High Output" HO motor, the last true 1.9 HO was in 1990. You have just a regular old 88hp 1.9 SEFI motor.
I make slow Escorts less-slow.
My cardomain
